It is currently Tue Aug 19, 2025 10:51 am
 Post subject: Kerfing...Make?...Buy?
PostPosted: Wed May 05, 2010 5:27 pm
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
Okay, I guess just a quick poll on kerfing to find out how many make it vs. buying it. I've seen the kerf making jigs but at some point don't you just want to build guitars? Making a kerf jig seems like overkill for a non pro builder like me I might have a different POV if this was my profession. I get that jigs are helpful but I'm kind of jigged out if you know what I mean.
PostPosted: Wed May 05, 2010 5:42 pm
No jig required - I gang 3 small Diablo blades with spacers between, put a mark on the blade insert for spacing, kerf the stock with miter guage and a block of wood to hold down the blank (each side radiused on the router table - reverse kerf style), and then rip. I even taped 2 pieces together and got a whole guitar set done in one go.
Easy.
Gabriel Regalbuto
Carlsbad, California
Freedom 35!
PostPosted: Wed May 05, 2010 5:46 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
I buy them, they are fairly cheap. I'll worry about making my own later down the road.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Wed May 05, 2010 5:49 pm
I make my own Mark. Usually reverse kerf out of Spanish cedar, spruce, walnut, mahogany etc. I don't really have a jig. It's just a piece of 3/4" ply with a kerf that I fit over the bandsaw blade from the back of the blade and clamp to the table. I just slide it so that the depth is right, make a pencil mark 3/16" or so on each side of the blade onto the plywood itself. I roundover one edge on each side of a board on my router table and rip two linings off on the tablesaw and repeat. I then slot on the bandsaw butting the glue side face of the lining against the clamped plywood and using the pencil mark as a reference. Usually a test cut or two and a couple of hammer taps and things are set perfectly. I can slot up enough for a couple of guitars in about 15 minutes. Not a production setting but works well for me and my pace of work.
PostPosted: Wed May 05, 2010 5:56 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
Buy - at $4 a piece from Colonial - it isn't worth the bother to set up unless you are going to make a boat load.
But lately I've been doing solid linings, which I love. No kerf lining required
John Ressler
PostPosted: Wed May 05, 2010 5:57 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Made mine. On the bandsaw, just put a stopper and a mark on the guide for the spacing. Really easy, fast. When you do it, do a lot.. you can get 20-25 sticks in about an hour. And you have them for many guitars. And if you make them with some retail of anything... they almost have kerfing for free
my 2 cents!
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Wed May 05, 2010 6:13 pm
Like John, I'm ripping solid linings...no kerf for me.
PostPosted: Wed May 05, 2010 6:21 pm
First name: Peter
Country: England
I buy mine. I have a supplier from eBay who supplies my brace wood also who runs his own lumberyard and sells guitar stuff more as a hobby. He recently sent me a video of his kerfing jig which works on an industrial scale as he sells it for a huge amount of uses other than guitar making.
PostPosted: Wed May 05, 2010 6:34 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I buy mine. If I ever accumulate enough long offcuts from Mahogany and/or Spruce I would make my own. Too easy and cheap to buy right now and what I buy works well.
Tim
PostPosted: Wed May 05, 2010 7:27 pm
I make my own with my bandsaw. That way they can be made with woods i prefer over what they sell.Most places only offer mahogany or basswood which i don't like to use anyway.
PostPosted: Wed May 05, 2010 7:35 pm
First name: Tom
Last Name: West
State: Nova Scotia
Make my own. One of those jobs where you can get a rhythm going and crank out piece after piece. I made and used reverse linings for the first time last winter on three guitars. As Mr. stock says easy to make,easy to glue. And much easier and neater to do the in letting for braces. I'm not going back to triangular. Reverse also stiffen up the sides very nicely.
Tom
PostPosted: Wed May 05, 2010 7:40 pm
Last Name: Neal
City: Arcadia
State: ok
Zip/Postal Code: 73007
I got a question for you guys that make them. Do you need to use qtr.sawn or will plane sawn work?
PostPosted: Wed May 05, 2010 7:43 pm
City: Tucson
State: AZ
Another vote for solid linings. They just look so much more elegant to me, plus they stiffen up the sides a bit.
PostPosted: Wed May 05, 2010 8:00 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I made enough for 8 builds a while back(reverse, on my band saw) but after using it up I went back to buying it. For me it's not expensive to buy, and life's too short to spend time making kerfing. I may try solid linings sometime just for kicks.
PostPosted: Wed May 05, 2010 8:12 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
I buy it. I'd rather spend time on the fun parts of the build.
Chris.
PostPosted: Wed May 05, 2010 9:11 pm
I make my own in a large batch but I am thinking about trying some of Kevin Ryans cool stuff soon.
PostPosted: Wed May 05, 2010 9:29 pm
Last Name: Abercrombie
Solid or laminated linings for me as well.
PostPosted: Thu May 06, 2010 8:05 am
I did 8 guitars worth one night and will probably never do that again...
Many of our sponsors here sell it so cost effectively in assorted styles and species that it's really hard to justify going cross eyed cutting kerfs.
I have to give a thumbs up to Kevin Ryan's lining as it's so easy to install and basically just cool!
Ray
Guitar Building = Continuous Improvement Process
PostPosted: Thu May 06, 2010 8:06 am
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Thanks I appreciate the input. I've never tried solid linings I'll have to check it out.
PostPosted: Thu May 06, 2010 8:58 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I make my own. It really is easy and fast. I am also of the mind that if I am making a guitar, I am making the whole guitar. I also don't buy pre carved necks or bridges, slotted fingerboards, etc... Many peopled do, I'm not putting them down, but it just never occurs to me to buy that stuff.
http://redrivercanoe.ca/
PostPosted: Thu May 06, 2010 9:19 am
Ditto.
Alain Moisan
(Now building just for fun!)
PostPosted: Thu May 06, 2010 9:48 am
Ditto.
Ditto (...maybe it's a Canadian thing! ;) )
(I did a tutorial long time ago on reverse style if anyone's interested)
Milton, ON
PostPosted: Thu May 06, 2010 10:18 am
First name: Jim
Last Name: Kirby
My kerfed linings have all been purchased, but I'm tending now towards laminated linings, or using the individual little blocks when needed for classical builds.
Jim Kirby
kirby@udel.edu
PostPosted: Thu May 06, 2010 11:31 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I make mine too. Three blades ganged together with spacers (.290" alum discs) and a sled like the one used to cut fret slots. I tape ten to twelve pieces together & go at it. In an easy few hours, I can make enough for ten or fifteen guitars.
If I was building one or two guitars a year, I buy 'em.
Nice thing about building your own is you can get them as flexible or as stiff as you want. And you can use better material than some suppliers use. (less breakage)
I'm thinking about solid linings too, these days. Next guitar, I'm gonna give 'em a try.
PostPosted: Thu May 06, 2010 12:54 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Us Canadians are a frugal bunch, it is said in Florida that Canadian tourists are like Catamaran sail boats, never tip.
So far I have used uncle Bob from RC kerf lining so I am the different Canadian, but some may think those of us in South western Ontario are not real Canadians anyhow.
Fred
Fred Tellier
Users browsing this forum: DennisK and 12 guests
